Date/Time: Tue, 08 Sep 2026 15:24:14 +0000
sc.IsFullRecalculation
View Count: 2327
| [2019-03-02 19:27:44] |
| User982736 - Posts: 46 |
I am trying to use code I found from the examples that call IsFullRecalculation function. I found that if I call that code as they did, the 20 period moving average is not returning the correct value. If I comment that call out the moving average is correct. When is it appropriate to use this function and why does the moving average not calculate correctly when using it? // Section 1 - Set the configuration variables and defaults if (sc.SetDefaults) { sc.GraphName = "Trade Test Daily PL"; sc.AutoLoop = 1; //Automatic looping is enabled. return; } // Section 2 - Do data processing if (sc.IsFullRecalculation) return; sc.MovingAverage(sc.BaseDataIn[SC_LAST], sc.Subgraph[1], MOVAVGTYPE_EXPONENTIAL, 20); float MovingAverage = sc.Subgraph[1][sc.Index]; SCString MessageString; MessageString.Format("EMA: %.2f", MovingAverage); sc.AddMessageToLog(MessageString, 0); |
| [2019-03-02 22:36:46] |
if (sc.IsFullRecalculation) This code must be removed.return; Using that variable would be to perform certain initialization during a full recalculation but not returning before performing the data processing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-02 22:37:02
