Date/Time: Wed, 24 Apr 2024 19:09:15 +0000
Auto Adjust Region 2,3,4 in equal height
View Count: 976
[2019-03-02 15:45:10] |
User164231 - Posts: 278 |
Is there a way to set height automatically when I create a new chart for region 2, 3, and 4?
[2019-03-03 13:08:01] |
SpearChucker - Posts: 101 |
Following
[2019-08-22 12:47:30] |
User786248 - Posts: 25 |
any tips on how to set height for chart region 2, 3, 4 in equal height? thanks |
[2019-08-22 23:53:34] |
There is no way to do this automatically. It needs to be manually done: Working With Charts: Chart Window and Regions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-08-22 23:54:49
[2019-08-23 02:13:26] |
Actually if you link your chart and studies you could simply 'apply' any study and they will all synchronise. You then have to lock the region and change study accordingly. Not a fix but better than nothing.
