Date/Time: Mon, 27 Jan 2025 16:58:24 +0000
Draw Style Scroll Bar on Study Settings Subgraphs: Does not Function.
View Count: 626
[2019-03-01 16:00:11] |
User73463 - Posts: 21 |
Draw Style Scroll Bar on Study Settings Subgraphs: Does not Function. Once my mouse moves to scroll at the Bar the menu disappears to the draw style that the mouse covered while crossing to use the scroll bar. The only way to function is to move mouse to top or bottom of menu for moving to different style. Version 1873 and previous.
[2019-03-01 17:26:18] |
This is Windows operating system level behavior although we do not observe this ourselves. It is not something that is within our control. However, obviously are going to have to replace this Microsoft trash with our own drop-down list box. We will do that at some point. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-03-01 17:26:29
