Date/Time: Mon, 27 Jan 2025 19:42:21 +0000
Is sc.GetStudyIDByName obsolete in 64-bit?
View Count: 869
[2019-03-01 12:30:42] |
Blue Brazilian - Posts: 42 |
I successfully compiled a 32-bit version of a study that includes a call to sc.GetStudyIDByName, but when I compile the study for 64-bit, I get the following compilation error: error C2039: 'GetStudyIDByName': is not a member of 's_sc' Is there an alternative function in 64-bit that does the same thing? |
[2019-03-01 12:42:09] |
What compiler are you using? You must be using an old header file.
[2019-03-01 14:33:31] |
Well, I just re-installed the compiler and get the same message. Which header file do you suspect is out of date?
[2019-03-01 17:35:01] |
Make sure you are using this header file in your Sierra Chart installation folder: /ACS_Source/SierraChart.h. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-03-02 00:09:04] |
Updating to the latest version of he header file fixed the problem. Thanks. |
[2019-03-03 00:01:10] |
If that header was out of date, you need to make sure to include all of the other header files from the /ACS_Source folder. They are all matched with each other.
