Date/Time: Mon, 27 Jan 2025 17:05:09 +0000
Updated to latest version and all chartbooks open blank
View Count: 941
[2019-03-01 05:45:08] |
User566779 - Posts: 24 |
The only thing that opens in my old chartbooks is the DOM. I created a new chartbook and it reopens ok but I can't access any of my chartbooks prior to the upgrade.
[2019-03-01 08:41:23] |
Were you updating from a significantly older version? Can you attach the Chartbook you are trying to open, here by following these instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
