Date/Time: Mon, 27 Jan 2025 16:56:53 +0000
CPU Thrashing
View Count: 1041
[2019-03-01 00:31:14] |
User29662 - Posts: 76 |
When I was running 32-Bit Sierra Chart, I noticed a lot of CPU thrashing. One of my four cores was constantly hitting the 25% level while others were not being used. I recently upgraded to 64-Bit Sierra Chart and was hoping it would use more then one core, but I'm not sure it is. Should it be? Thanks, Roy |
[2019-03-01 01:12:40] |
Actually, maybe I'm wrong. It looks like all four cores are being used now. Can you give me a definitive answer as to whether the 64 bit version makes better use of multi-core cpus or not?
[2019-03-01 01:51:56] |
The 64-bit version is not going to make use of more CPU cores.
[2019-03-01 01:55:52] |
Thanks for the clarification!
