Date/Time: Mon, 27 Jan 2025 17:07:10 +0000
Draw Volume Profile tool linking to chartbook question
View Count: 978
[2019-02-28 21:25:58] |
User844383 - Posts: 40 |
I finally realized that SC has the "floating volume profile", which is awesome. I am however having a problem, and I'm thinking it's the way I have my chartbooks and charts set up. I have a Grains chartbook with a quoteboard linked to the chart. If I use the DVP tool on the corn contract and then switch to wheat, the profile is still there with the same dates and times as the corn. It shows the wheat profile correctly, but I'm wondering if there is a way to keep the profile linked to the corn, or whatever contract, instead of staying linked to whatever is in my chartbook. I'm thinking it's probably how I have my SC set up... I have Grains, Livestock, Bonds, etc chartbooks. Each chartbook is linked to their own quoteboard so I just click on whatever in my quotes and it pops up in the linked charbook. Any suggestions on how I can make this work? Thanks!!
[2019-03-01 01:49:42] |
This will be solved in the next release as long as this option is disabled: Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
