Date/Time: Mon, 21 Sep 2026 17:16:53 +0000
Use of SCString::Tokenize()
View Count: 1186
| [2019-02-28 19:07:11] |
| User470516 - Posts: 78 |
Dear SC Team, Would it be possible for you to add an example of how to use SCString::Tokenize() in the documentation please, as you have done with Format and other functions ? I do not understand the syntax so I can't have it work. I have no problem using SCString::GetChars() or Format but I fail with Tokenize. There is an example in the following file : RequestValuesFromServerAndDraw.cpp but it is too complicated for me to understand. Thank you for the support. Regards, Laurent |
| [2019-03-06 11:11:17] |
I have written a function that does what SCString::Tokenize() is supposed to do as I have yet to understand how it works as I indicated in my previous post. Is it possible for you to write an example of SCString::Tokenize() use in the documentation or is my question out of the scop of your support, in which case, I'd like to be so advised, so I don't count on it? Thank you for your support. Laurent |
