Date/Time: Sun, 24 Nov 2024 14:57:08 +0000
Arrow Alert/Signal
View Count: 1895
[2013-11-15 15:35:47] |
crossiman - Posts: 29 |
I have a "Highest High/Lowest Low over n Bars" - study on a chart. What I want is to hide this study and therefore an arrow should be displayed when the high of a bar is crossing over the upper line of the study and if it crosses below an arrow down should appear over this bar. But: the arrow should only appear once a new signal is triggered and not each time when the high/low of a bar penetrates the high/low of the study. So if the last signal was an up arrow the next signal arrow could only be a down arrow. I know that the study inputs must be displaced by +1. Is there a possibility to user the crossfrombelow/crossfromabove functionality ? Could you please assist me in here urgently ? Many thanks !!! |
[2013-11-15 17:47:06] |
We can only say that you can do this with the Color Bar Based on Alert Condition study: http://www.sierrachart.com/index.php?l=doc/doc_TechnicalStudiesReference.html#s245 We cannot provide the specific formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
