Date/Time: Mon, 27 Jan 2025 05:09:40 +0000
Market Depth Historical in v1880
View Count: 819
[2019-02-28 10:18:43]
samual sprat - Posts: 343
The latest update has completely changed how it works in terms of colouring and I can't get it to look how i want now. I'm not interested in the different colouring gradients and thresholds. How do I set the colours and percent color thresholds so that they're all displayed like they were before you added this functionality (like in 1850)
I tried to set the percent color thresholds to 100,100,100 and all colours to the same, but the closest values when they are small like 0-20 light up brighter than values like 100. I assume that the 100,100,100 need to include the closest too, so 100,100,100,100 but that does nothing. I've got no idea
S
Date Time Of Last Edit: 2019-02-28 10:45:44
[2019-02-28 14:59:55]
User972768 - Posts: 166
Sunnyod, take a look at another ticket, you might find an answer for how to get "old logic" back: v1878 breaks Market Depth study
HTH
[2019-02-28 15:32:15]
User972768 appreciated!
[2019-02-28 17:00:27]
John - SC Support - Posts: 37478
As noted, the answer is to use Percent Color Thresholds set to 0, 0, 0. This will force the colors to only use the Range 3 Bid/Ask Color. Then everything will work as it has in the past without the multiple colors.
