Date/Time: Mon, 27 Jan 2025 05:03:00 +0000
Candlesticks
View Count: 668
[2019-02-28 00:01:15] |
Robert Wojczak - Posts: 145 |
Is there any way to make the wicks thicker on candlesticks?
[2019-02-28 08:18:15] |
Yes this is done through the Graphics Settings window. Refer to: Graphics Settings Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
