Date/Time: Mon, 27 Jan 2025 05:06:36 +0000
[Programming Help] - Color bar based on alert
View Count: 1053
[2019-02-27 19:13:58] |
Ro - Posts: 10 |
Hi, I have created a simple alert condition that highlights a bar if the current period close is higher than the prior volume value are high (VAH) AND(C>ID7.SG2[-1], C>ID7.SG2[-2]) I would like the alert on the hourly chart to actually highlight the current period bar if the close is higher than the prior day VAH and the prior 2 day VAH. Is this possible? Thanks, R |
[2019-02-28 08:43:21] |
Yes this is possible. You will want to add the Volume Value Area Lines two additional times to the chart. One referencing the prior period and another one referencing 2 periods ago. You can then reference these study subgraphs from this study in the alert formula. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-28 08:43:50
