Date/Time: Sun, 24 Nov 2024 16:58:28 +0000
only 5 levels in the DOM?
View Count: 1288
[2013-11-15 14:08:40]
9baller - Posts: 38
just upgraded to new version 1046 and now there are only 5 levels in the DOM?.....always had 10 before...have been using ten...need ten
[2013-11-15 15:10:40]
9baller - Posts: 38
ok rolled back to earlier version 1032 and dom is corrected...now my commissions are not being calculated in statistics...is there a setting for this that I am missing?
[2013-11-15 18:13:59]
For help with the Use Commission setting on the Trade Activity Log, refer to:
http://www.sierrachart.com/index.php?l=doc/doc_TradeActivityLog.php#Controls
[2013-11-19 15:55:57]
User84940 - Posts: 9
Is there a way to get 10 levels with out downgrading to a lower version ?
[2013-11-19 17:47:50]
No, unless you were to use our own data feed:
http://www.sierrachart.com/index.php?l=doc/SierraChartRealTimeFuturesStockDataFeed.php
