Date/Time: Mon, 27 Jan 2025 04:37:36 +0000
Why is the data discontinuous and jump from December 9, 2015 to September 8, 2016?
View Count: 956
[2019-02-27 17:48:45] |
Jack2 - Posts: 10 |
Why is the data discontinuous and jump from December 9, 2015 to September 8, 2016? The symbol of the chart is s&p 500 mini-futures ES. How to solve this problem?
[2019-02-27 17:55:49] |
Jack2 - Posts: 10 |
the following is the message log: ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2017-12-14 10:00:00. Next Bar Date Time: 2017-12-14 09:30:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:30 ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2017-12-27 09:30:00. Next Bar Date Time: 2017-12-27 08:30:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:30 ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-10 11:30:00. Next Bar Date Time: 2018-01-10 10:30:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:30 ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-15 08:00:00. Next Bar Date Time: 2018-01-15 06:30:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:30 ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-25 11:30:00. Next Bar Date Time: 2018-01-25 11:00:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:30 ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-26 09:30:00. Next Bar Date Time: 2018-01-26 09:00:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:30 ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-01-26 12:30:00. Next Bar Date Time: 2018-01-26 12:00:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:30 ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-06-11 12:30:00. Next Bar Date Time: 2018-06-11 11:30:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:40 ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-09-05 12:30:00. Next Bar Date Time: 2018-09-05 12:00:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:41 ES-201903-GLOBEX [CV] 30 Min #7 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2018-09-07 12:30:00. Next Bar Date Time: 2018-09-07 09:30:00. Filename: ES-201903-GLOBEX.scid | 2019-02-27 09:50:41 NISS-NYSE [C] [M] 30 Min #1 | Chart Settings have been synchronized between Destination chart number #7 and Source data chart number #1. Performing a chart reload of Source data chart. Chartbook: Market Cycles v5old.cht | 2019-02-27 09:50:43 NISS-NYSE [CV] [M] 30 Min #1 | Reloading chart. | 2019-02-27 09:50:43 NISS-NYSE [CV] [M] 30 Min #1 | No contract months found for symbol. Unable to build continuous futures contract chart. | 2019-02-27 09:50:43 NISS-NYSE [CV] [M] 30 Min #1 | There are no continuous futures contract symbols. Loading data normally. | 2019-02-27 09:50:43 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Market Cycles v5old.cht | 2019-02-27 09:50:51 Chart #1 has tagged chart #7 for full recalculation. Chartbook: Market Cycles v5old.cht | 2019-02-27 09:50:51 ES-201903-GLOBEX [CV] 30 Min #7 | Performing a full recalculation because it has been tagged. Chartbook: Market Cycles v5old.cht | 2019-02-27 09:50:51 |
[2019-02-27 18:18:23] |
Make sure you are using the Sierra Chart Historical Data Service: Interactive Brokers Trading Service: Using Sierra Chart Historical Data (Using Sierra Chart Historical Data) And then follow these instructions: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-27 18:18:39
