Date/Time: Mon, 27 Jan 2025 16:53:22 +0000
User Question
View Count: 887
[2019-02-27 16:23:59] |
Sierra Chart - Max - Posts: 5780 |
Is it possible to tilt at an angle instead of only horizontal or vertical?
Sierra Chart Support |
[2019-02-27 18:14:25] |
What type of Chart Drawing are you referring to tilting?
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-27 18:15:45
[2019-02-28 15:33:57] |
It there any way to tilt the ellipse. (GANN ellipse)
[2019-03-01 03:57:02] |
It is not supported to rotate the ellipse. It is only Horizontal/Vertical.
