Date/Time: Mon, 27 Jan 2025 04:51:49 +0000
Historical Data Search
View Count: 532
[2019-02-27 01:27:13] |
User20202020 - Posts: 18 |
Hi, Is there a way I can run a search the historical data for a particular stock for movement that hits a specific velocity? For example, is it possible to search the historical data of a stock and have a list provided which identifies all of the days/times a stock had a 9% velocity or higher? Thanks! |
[2019-02-28 09:00:06] |
You can certainly create a custom study to do this. But you would have to work out the details.
