Date/Time: Mon, 27 Jan 2025 17:04:57 +0000
Running Sierra Chart on a 2nd Computer
View Count: 761
[2019-02-27 00:13:05]
User94606 - Posts: 327
I am planning to install Sierra Chart on a 2nd computer (laptop). I am currently have a subscription to Sierra Chart Real-Time and Historical Exchange data feed. Can I run both computers and get real-time market data at the same time? Or only one computer can only be receiving real-time market data?
[2019-03-01 00:39:21]
Following up for a response
[2019-03-01 01:53:37]
In this particular case you just need to activate a second real-time data connection:
https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#Connections
[2019-03-01 05:11:02]
Acro - Posts: 441
If you are on the same intranet then I think you can set up the first computer as your DTC server and use that datafeed on the second one.
I've done just that on a single datafeed
[2019-03-01 05:19:17]
The new SierraChart installation will be on a laptop that I will be using when I travel. In this case, only one real-time data connection will be active. Can I use the existing real-time data connection?
[2019-03-01 05:23:40]
Yes of course this is no problem.
And you can do what is described in post #4. It is just more technically involved and that is why we usually do not suggest it.
[2019-03-01 05:31:36]
So I can reuse the existing real-time data connection on the laptop as long as the real-time data connection on the desktop is not active.
Do you have instructions on how to setup the DTC server proposed in post #4?
[2019-03-01 23:38:34]
Yes.
To answer your other question, refer to:
Using DTC Server for Data and Trading in Another Sierra Chart Instance
