Date/Time: Mon, 27 Jan 2025 16:56:56 +0000
Attached Orders
View Count: 1134
[2019-02-26 21:45:16] |
User294224 - Posts: 43 |
Is it be possible to create an attached that when say a limit order in crude oil is filled an order is sent to market in the brent oil contract? I am aware there are exchange traded products which can do this for these products but it is an order function that I would find useful if I could create myself. |
[2019-02-26 22:51:31] |
There is no built-in way to do something like this. Although you can certainly trade a different symbol than the chart is set to.
[2019-02-26 22:56:36] |
Would there be a way I could create an attached market order in another product through the spreadsheet perhaps?
[2019-02-27 13:45:52] |
Also, do you think there is any possibility of a feature like being in-built at some point in the future?
[2019-02-27 18:48:05] |
You could use ACSIL: Automated Trading From an Advanced Custom Study We do not see this as being added as a built-in feature. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-27 18:48:30
[2019-03-01 10:23:14] |
User90125 - Posts: 715 |
Does this mean the attached orders will also have the different symbol as well then? |
[2019-03-01 11:10:02] |
Yes I was wondering this too?
[2019-03-01 18:31:43] |
You can use ACSIL to submit an order for any symbol. So the way you can do this is to use ACSIL to monitor for a parent limit order which has been submitted and then filled. And when that is detected, submit the other order for the other symbol.
