Date/Time: Mon, 27 Jan 2025 04:37:46 +0000
Control Bar window settings
View Count: 719
[2019-02-26 15:14:22] |
User786248 - Posts: 25 |
Hi How do I copy the settings of my control bar #4 into a new instance of sierra chart? thanks |
[2019-02-26 17:39:14] |
The Control Bar settings are located in the Sierra3.cfg file which is in the main Sierra Chart folder. You can just copy this file into the folder for the new instance. Just be aware that this contains all the configuration settings, so you will get all the settings from the instance that you copy this file from, not just the Control Bar settings. The following documentation gives information on the files and their locations, but you do not want to follow the full instructions as you only want the one file: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation: Transferring Sierra Chart Settings and Data From Existing Installation to New Installation Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
