Date/Time: Mon, 27 Jan 2025 05:06:15 +0000
Color Tabs and Lists
View Count: 826
[2019-02-26 12:37:05] |
User897083 - Posts: 1 |
It appears that "Chart Tab Color" and "Chart Tab Text Color" do not appear in the Chart > Graphic Setting - Chart menu but, do appear in the Global Settings > Graphic Setting - Global menu. The support documentation appears to me to indicate that individual tabs can be colored when you de-select the global check under the Chart Menu. I would like to classify and identify individual charts by tab color or text or background color in lists. I am running AT Version: 1859 32-bit (25894-25900M)
[2019-02-26 19:39:30] |
This is not supported. Those tab colors are global color settings.
