Date/Time: Mon, 27 Jan 2025 05:08:39 +0000
MP Und VP
View Count: 706
[2019-02-25 15:20:48] |
User608368 - Posts: 1 |
Hallo, warum kann ich mit meinem Packages 5 kein MArket Profile und Volume Profile einfügen? |
[2019-02-25 19:37:55] |
You are on Package 5, and you should be able to use the Volume by Price and TPO charts without any issues. Follow the instructions here for Force Login to ensure that your system has the correct information from our servers: Sierra Chart - Software Login Instructions: Forced Login If that does not resolve your problem, then attach the Message Log after you try to add one of the studies to the chart and it fails. Follow the instructions here for how to attach the log: https://www.sierrachart.com/index.php?page=PostingInformation.php#MessageLog Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
