Date/Time: Mon, 27 Jan 2025 05:01:39 +0000
[User Discussion] - Some Trading Keyboard Shortcuts not working on different instances
View Count: 1051
[2019-02-25 11:48:00] |
samual sprat - Posts: 343 |
Hi, If i've opened or placed a live trade in main instance, have trade simulation mode disabled and chart trade mode enabled in a sub instance, I can see the horizontal lines on sub instance displaying the order/target/stop's. I can move the order/target/stop on sub instance using the mouse, but cannot use keyboard shortcuts to move the order/target/stops. Cancelling/Flattening the order/position works for some reason, but the following don't work (and possibly more): - non-attached limit order tick up/down - stop order tick up/down - target order tick up/down If the trade is placed in the sub instance and I try to control from the main instance, then I can move stop order and target order but not the limit. Not sure why Am I doing something wrong or are some specific settings needed to do this? Thanks S Date Time Of Last Edit: 2019-02-25 12:37:27
[2019-02-25 19:45:48] |
We cannot help with keyboard shortcuts. Based on your prior posts related to this, this is going to be an operating system issue in your case. , then I can move stop order and target order but not the limit. The target order is a limit order. So what are you referring to? There should be no problem with this.
