Date/Time: Sat, 26 Apr 2025 09:42:44 +0000
Quickly Changing chart Timeframes without reloading entire chart history
View Count: 729
[2019-02-24 22:14:21] |
mikeb029 - Posts: 25 |
Hello, I'd like to be able to change chart time frames without having to reload the entire chart history. For example, I have a 4hr continuous contract /ES chart for a 5000 day period of time. I'd like to change that chart to a smaller time frame without having to wait the 2-3 minutes it takes to reload the entire 5000 day period. So, if select 30 minute time frame, is there a way to set it so it only loads 90 days of data? Or, is there any other way to speed change of time frames within a chart that has a long history? Thank you, Mike Beck |
[2019-02-24 22:56:32] |
To improve the speed of loading data, refer to this particular section: Changing Chart Bars Period: Improving Performance of Loading Chart Data Also refer to this particular setting: Chart Settings: Adjust Proportional With Bar Period (Chart >> Chart Settings >> Data Limiting >> Load Data Limiting Method: Days to Load menu) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-24 22:58:04
[2019-02-25 02:03:44] |
Thank you for the quick response. Ultimately, the fix ended up being checking the box next to "adjust proportional with bar period." Thank you |
