Date/Time: Mon, 27 Jan 2025 05:06:15 +0000
How to replace s shortcut for second period ?
View Count: 605
[2019-02-24 20:09:17] |
TedMar - Posts: 190 |
Hi, if replace (second) period shortcut "s" with my trading keybord command, i dont have after shortcut for second period. How is posible set other shortcut for seconds ? I can find this command in "Customize Keyboard Shortcuts" And why loocked Shift is not same as Shift? I would like make shortcuts with loocked SHIFT. Any Idea? |
[2019-02-24 21:58:29] |
That periods code is not changeable. And why loocked Shift is not same as Shift? I would like make shortcuts with loocked SHIFT. Any Idea? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-24 22:00:02
