Date/Time: Tue, 01 Apr 2025 22:07:56 +0000
T&S Settings - Same Time and Type - Vol Filtering not works
View Count: 815
[2019-02-24 09:09:27] |
TedMar - Posts: 190 |
Input Filtering by Volume NOT works correctly with Combine Records "Same Time and Type". Input Filtering settings, filtered and display raw order Volume only. Unposible to Filter by Volume with "Same time and Type" Highlight Settings by Volume works correct. Date Time Of Last Edit: 2019-02-24 14:02:54
[2019-02-24 14:02:25] |
Refer to the documentation for these settings here: Time and Sales Window: Combine Records >> Do Not Combine Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
