Date/Time: Sun, 02 Feb 2025 06:57:43 +0000
Auto Scale similar to TradingView?
View Count: 2641
[2019-02-24 05:57:31]
truth - Posts: 2
I was wondering if there is a way to get the chart to auto scale while wheel scrolling? Like on TradingView
https://www.tradingview.com/chart/
Make sure "auto" in the bottom right hand of the chart is checked.
I have done the "Scroll Multiplier" and my "Scale Range Automatic" but what I am looking for is for the last price action bar to stay put while the other past candle sticks scroll towards it.
Like on the TradingView, please try it so you understand. I think the issue is with me being ignorant on what this is called so I am unable to know what to look for in the Sierra documentation
Also, If anyone has a ChartBook that is similar to TradingView layout. Please share :)
[2019-08-29 12:50:59]
User266069 - Posts: 30
not sure if you will see this, but i found the closest thing to how tradingview scroll is the following
with Scale range: automatic selected, right click price
1) reset
2) interactive scale locked
Date Time Of Last Edit: 2019-08-29 12:52:34
[2019-08-29 19:22:01]
It looks like you want to use the Constant Range scale setting with Keep the Last Bar Within View for the Constant Range Scale Mode. Refer to the documentation here for these settings:
Chart Scale and Scale Adjusting: Constant Range (Scale Range)
