Date/Time: Mon, 03 Mar 2025 15:17:16 +0000
Unable to get Agreement status due to communications error
View Count: 1454
[2019-05-01 22:51:09] |
Please try again. This should now be resolved.
Sierra Chart Support |
[2019-06-19 08:51:58] |
Stephen Byrne - Posts: 2 |
Hi there, I'm having a similar issue - I don't currently have an active futures trading account as I'm in the process of moving out of a prop firm - is it possible to activate the GLBX without having an active futures trading account? Thanks, |
[2019-06-19 16:22:55] |
We see that you did successfully activate the CME E-mini exchange. Do you still need further help? - is it possible to activate the GLBX without having an active futures trading account? Yes.
