Date/Time: Mon, 27 Jan 2025 05:05:18 +0000
Disable Trade Entries
View Count: 635
[2019-02-23 02:52:07]
User228927 - Posts: 55
Is there a quick way to disable either buy side entries or sell side entries from auto spreadsheet study trading but not both.
[2019-02-24 02:09:24]
You can just do this through the formulas used on the Spreadsheet used by the Spreadsheet System for Trading study. The corresponding order entry column formula just should not return true.
