Date/Time: Mon, 27 Jan 2025 04:54:27 +0000
Automated Trading
View Count: 699
[2019-02-22 19:47:57] |
User94606 - Posts: 327 |
What is the best way to setup automated trading in SierraChart? I found the following reference but was not sure if this is the only approach? Spreadsheet Systems, Alerts and Automated Trading: Spreadsheet Systems, Alerts and Automated Trading |
[2019-02-22 20:14:17] |
The different methods are explained in the Introduction section here: Automated Trading Management Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-27 01:03:15] |
If I enable autotrading, do you recommend the following in Windows 10: 1. Set"sleep mode" in Windows 10 to "Never"? 2. Do I need to set Screen mode to "Never"? This is just to turn off monitor |
Windows 10 Power Options.jpg / V - Attached On 2019-02-27 01:03:01 UTC - Size: 69.64 KB - 267 views |
[2019-02-27 01:44:06] |
1. Yes 2. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
