Date/Time: Mon, 27 Jan 2025 04:37:35 +0000
DOM
View Count: 706
[2019-02-22 18:57:41] |
Dorian - Posts: 61 |
Hello, I would like to know if it is possible to display the real queue in the DOM where is the contract (that is to say that decreases to 1 then our contract is served), and not the queue of everyone. Best Regards, Dorian Stoll |
[2019-02-23 11:37:27] |
We are not sure which of two possible questions you are asking, so we will answer both. First, if you are asking how to display the quantities of your attached orders and not the full Market Depth, then you just need to customize the Column display to have the Buy and Sell Order Columns displayed rather than the Bid Size/Buy and Ask Size/Sell Order Columns. You will find the documentation for this here: Global Trade Settings Windows: Buy Order Column - Left/Center/Right Aligned If, on the other hand, you want to know where your particular attached order is in the queue, then refer to the following setting: Global Trade Settings Windows: Enable Estimated Position in Queue Tracking (Global Settings >> Chart Trade Settings >> General >> Position in Queue) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-25 13:08:22] |
Thank you so much! Excellent day. |
