Date/Time: Mon, 27 Jan 2025 04:47:38 +0000
User Question
View Count: 625
[2019-02-22 17:32:08] |
Sierra Chart - Max - Posts: 5780 |
Joe, It there any way to tilt the ellipse. Secondly How is the chart scaling done because it seems to match up nicely on a Gann square plotted using 8.5 inch square. Thanks Sierra Chart Support |
[2019-02-25 18:15:21] |
An ellipse drawing cannot be angled. Secondly How is the chart scaling done because it seems to match up nicely on a Gann square plotted using 8.5 inch square. We are not understanding this. However, refer to:Chart Drawing Tools: Drawing a Line with a Specific Angle or Slope (Drawing a Line with a Specific Angle or Slope Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-25 18:15:53
