Date/Time: Mon, 27 Jan 2025 04:59:08 +0000
From Date Range not working as expected after redownload more data
View Count: 630
[2019-02-22 09:56:37] |
wwwingman - Posts: 185 |
Hi When I copy one of my chartbooks to a new SC instance I lose the "From" Date Range in file of the loaded symbol. Enclosed-by a screenshot. The problem is that this leads to differences in the computation and since there are many charts I need to do manually the operation of increasing the date range for each chart, and this takes a lot of time. I would hope doing it only once for a chartbook and then use it on any SC, even a new one with no data. Please advise. -- W |
2019-02-22_03-31-10.png / V - Attached On 2019-02-22 09:52:37 UTC - Size: 104.71 KB - 275 views |
[2019-02-22 18:56:47] |
That is not a savable setting. It shows what is actually in the chart data file. This is adjustable. Refer to: https://www.sierrachart.com/index.php?page=doc/DataSourceSettings.php#MaxHistoricalIntradayDaysToDownload Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
