Date/Time: Mon, 27 Jan 2025 04:42:26 +0000
POC 100% Volume Profile on Trading DOM
View Count: 1579
[2019-02-22 01:59:40] |
User770116 - Posts: 6 |
Is there a way to set volume bars relative to POC bar? If the POC is at the extreme,taking up all the space, then the other bar would by dynamic, adjust to the POC volume. When the session first started, we don't have much volume, however, can we always have the POC filled out the available space, then all the other volume bars adjust to POC? Sorry if this is confusing.
[2019-02-24 02:46:35] |
The only options for the length of the volume bars are defined here: Volume By Price Study: Volume Bar Calculation Method Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
