Date/Time: Tue, 15 Sep 2026 22:15:57 +0000
Using sc.MakeHTTPRequest for shared files on cloud
View Count: 1757
| [2019-02-21 14:58:47] |
| @sstfrederik - Posts: 413 |
Hi, A few years back when I started I made a study that could grab a csv file from a shared google drive link made with this tool: https://sites.google.com/site/gdocs2direct/ There would generally be a redirect response which I would than use to grab the actual file contents. Currently sc.MakeHTTPRequest gets a 404 response when such a link is requested. So this no longer works. an example link is this one which should provide a few numbers. https://drive.google.com/uc?export=download&id=1arRrMQE84xBvZ8lPBmpYLTY6cAPGoZqP I have a few studies made that work fine on direct links to files on selfhosted servers, but it would be great if I could support users that are not to technical. Anything you guys can do? Thanks. Frederik |
| [2019-02-22 03:45:33] |
We are looking this over but it looks like the URL has moved.
| [2019-02-22 06:29:37] |
With any other tool I get a 302 temp moved message. I was hoping the sc. HttpResponse could at least be filled with that. Instead I get a 404 not found when I parse the response.
| [2019-03-01 08:56:23] |
Google drive always redirects the initial link. By using https://httpstatus.io/ with the link above you can see a 302 redirect to the actual file. when I view the sc.HTTPResponse in the message log I get a 404 output as seen below: <HTML> <HEAD> <TITLE>Not Found</TITLE> </HEAD> <BODY BGCOLOR="#FFFFFF" TEXT="#000000"> <H1>Not Found</H1> <H2>Error 404</H2> </BODY> </HTML> Somehow it seems that sc.MakeHTTPRequest gives up and produces a standard 404. Can sc.MakeHTTPRequest make the first response available in the sc.HTTPResponse? Thanks. |
| [2019-03-01 09:14:12] |
Test version 1880. This now should be resolved.
