Date/Time: Mon, 27 Jan 2025 05:03:29 +0000
importing file
View Count: 715
[2019-02-21 01:46:29] |
User228927 - Posts: 55 |
Having trouble importing trades into trade activity log from a previous saved file log in sierra charts.. Trying to import either of the top 2 files on the list.
Private File |
[2019-02-21 18:14:16] |
Attach here the actual file you are trying to import and we will test it.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-21 18:14:37
[2019-02-23 02:49:17] |
File attached
02-20-19CrudeNewTradesList.txt - Attached On 2019-02-23 02:49:01 UTC - Size: 9.7 KB - 389 views |
[2019-02-24 02:30:44] |
That data cannot be imported. That is nothing more than saved data from the Trades tab.
