Date/Time: Sun, 24 Nov 2024 16:04:44 +0000
custom study not appearing on charts
View Count: 1262
[2013-11-14 21:15:53] |
dennisdorsch - Posts: 4 |
custom study appears in data file for SC and appears in study list but does not display on chart when selected
[2013-11-14 21:18:34] |
What custom study is this?
[2013-11-14 21:25:38] |
a automated crossover trading system coded by Onn in may2012. it was working but after a long absence by me does not appear on charts. contacted Onn but seems to be unavailable
[2013-11-14 21:51:14] |
Do you have the source code for it? Please obtain the source code for it from them if you do not have it. After this we recommend recompiling it. Here are the instructions to recompile: http://www.sierrachart.com/index.php?l=doc/doc_BuildCustomStudiesDLL.html Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2013-11-14 22:39:48] |
working on this further find study on the very bottom 0 scale of chart and log stating custom autotrader needs to be recompiled for this version [up to date] of sc
[2013-11-14 23:15:28] |
We will contact Onn for you about this.
