Date/Time: Mon, 27 Jan 2025 04:46:23 +0000
windows error 1114 inquiry
View Count: 1024
[2019-02-20 17:32:41] |
onnb - Posts: 662 |
Probably not SC issue but I've been seeing this lately and am curious if you have seen this as well and have any idea. I am on build 1850 CreateStudyDLLModuleFunctionObject Error loading D:\SierraChart\Data\BlaBla.dll. Windows error code 1114: A dynamic link library (DLL) initialization routine failed. | 2019-02-20 11:20:12 * |
[2019-02-20 18:25:06] |
We did have a user report this about three weeks ago. We do not know what the reason is but it could not be an issue within Sierra Chart. Nothing has changed recently with how a DLL is loaded either. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-25 19:31:29] |
onnb - Posts: 662 |
Just shedding more light on this for what its worth. I thought might be specific to my custom dll's but I noticed that the UserContibutedStudies.dll also raises this issue. CreateStudyDLLModuleFunctionObject Error loading D:\SierraChart\Data\UserContributedStudies.dll. Windows error code 1114: A dynamic link library (DLL) initialization routine failed. | 2019-02-25 13:24:09 * |
[2019-02-25 19:39:50] |
Are you using that DLL from a 64-bit version of Sierra Chart? We are not aware of anyone encountering this with those custom studies and if they were we would be hearing about it from time to time. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2019-02-25 20:11:53] |
onnb - Posts: 662 |
fyi - It's for sure something in one of my dll's I'll continue to troubleshoot and will update here if needed. |
[2019-02-28 00:32:27] |
onnb - Posts: 662 |
Just another update on this, mostly for anyone running into this issue. Not 110% sure but looks like this might be related to the number or size of the custom study dll's in the Data folder. From we are seeing, if the total memory size of the dll's goes above some value you might start to get this error. Removing some dll's and the message disappears. |
