Date/Time: Mon, 27 Jan 2025 04:45:11 +0000
Activity Log - Trades - Total - wehre applicable
View Count: 517
[2019-02-20 16:13:50] |
TedMar - Posts: 190 |
Hi, some times (sim1 or Sim2) i get info bottom in Total row "wehre applicable", how i can remove this? and what is the reson for display them?
Date Time Of Last Edit: 2019-02-21 09:23:31
[2019-02-21 05:17:20] |
It relates to when there is a common currency used which is specified through Global Settings >> General Trade Settings. Set that the None.
