Date/Time: Mon, 27 Jan 2025 04:47:29 +0000
ALERT ON STUDY
View Count: 975
[2019-02-20 15:04:20]
Yeager - Posts: 128
I have a TPO study chart. There are value area hi/lo extension lines. I want to create an audio alert based on the extension lines (SG16.
I have written the alert C=ID.1SG16 however the audio alert is not triggering.
Is this the correct way to write for this alert?
Could not find specific documentation for this.
Many thanks
SAMPLE IMAGE HERE OFV THE areas I want the alert on
https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=26182
[2019-02-21 05:35:52]
No you need to use the TPO Value Area Lines study on a standard chart and create an alert formula for those study subgraphs.
Date Time Of Last Edit: 2019-02-21 05:36:16
[2019-02-21 07:17:51]
Yeager - Posts: 128
That makes sense.
And regarding the command. Would /=CROSSOVER work and should I use C for price or P?
[2019-02-21 08:57:33]
Yes you can use the CROSSOVER function and you would use C to get the last trade price of the bar. Refer to:
Study/Chart Alerts And Scanning: Available Main Price Graph Identifiers/Variables
