Date/Time: Sun, 26 Jan 2025 07:53:39 +0000
Daily charts repainting most recent bar
View Count: 594
[2019-02-19 19:27:38] |
mitchandsophtrading - Posts: 3 |
Hi guys, Can someone explain why my daily charts have started repainting the most recent daily bar? I can't figure it out and it is annoying the hell out of me. See attached. Thanks in advance. http://www.sierrachart.com/image.php?Image=1550604373524.png Mitch |
[2019-02-20 00:04:23] |
Make sure the time zone for that chart is using US Central or Eastern time: Time Zone Setting Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-20 06:48:13
[2019-02-20 06:41:49] |
Thank you!
