Date/Time: Sun, 26 Jan 2025 07:43:40 +0000
Real-time data
View Count: 1028
[2019-02-19 17:32:42] |
User495158 - Posts: 108 |
Hello! If I activate real-time connection for 20 real-time symbols (*Cash indices only*) will that include also S&P Futures to Cash Premium (ES?##-$INX)? |
[2019-02-19 18:54:44] |
No you cannot use that particular real-time connection option. You need to use the standard real-time connection options which are not limited to cash indices. And for an understanding of what exchanges you need to activate for premiums, refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#StockIndexPremiums However, you can always get historical data for those premium symbols. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-19 18:55:08
[2019-02-19 19:33:47] |
Ok, thanks! Could I get the same result using difference study for $SPX and ES? |
[2019-02-20 00:05:37] |
Not as accurately.
