Date/Time: Sun, 26 Jan 2025 07:25:57 +0000
Error Data Feed - gap where no gap may be
View Count: 616
[2019-02-19 15:09:58] |
User761472 - Posts: 2 |
Hello, I use Sierra on 2 pc and with one missing in Eurobund from 12 to 18 a few hours and thus a gap has arisen. Can you help me that I can correct this bug Thank you Date Time Of Last Edit: 2019-02-19 15:10:36
Screenshot 2019-02-19 10.08.18 SIERRA.png / V - Attached On 2019-02-19 15:10:34 UTC - Size: 154.77 KB - 256 views |
[2019-02-20 00:53:39] |
Since this is a continuous futures contract chart, follow the instructions here: Continuous Futures Contract Charts: Re-Downloading Continuous Futures Contract Data Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
