Date/Time: Sun, 26 Jan 2025 07:43:56 +0000
RBCL Futures Spreads Contract Not Visible
View Count: 714
[2019-02-19 15:09:00] |
EquinoxAnalytics - Posts: 10 |
Hi I am able to get data for LE, HE, RBHO , CLBZ But Not able to get spreads for RBCL. I am getting this Exchange spread data in TT platform, but i am using Sierra Charts for charting and analysis purpose. Can you Please enable data for these Spreads [ RBCL] Thanks Best Regards Manish |
[2019-02-19 18:37:10] |
Give us the very specific spread you are referring to which includes the month and year for each leg and we will check on this.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-19 18:37:19
[2019-02-19 19:06:26] |
Sierra Chart - Max - Posts: 5780 |
From User: https://www.sierrachart.com/Download.php?Folder=TicketingSystem&download=26170 Sierra Chart Support |
[2019-02-20 00:02:31] |
You need to get the spreads for CL futures and then you will see them listed. Here's an example: CL:C1 RB-CL N19.FUT_SPREAD.NYMEX Refer to: https://www.sierrachart.com/index.php?page=doc/SierraChartRealTimeFuturesStockDataFeed.php#ExchangeTradedSpreads Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
