Date/Time: Sun, 26 Jan 2025 07:52:39 +0000
Version 1526 or later beginning 3/9/19
View Count: 603
[2019-02-19 14:17:14]
Crazy_Bull - Posts: 17
I need clarification regarding the notice that "support for versions 1525 and earlier is going to be discontinued March 9, 2019"
Does this means that version 1525 and earlier will no longer be allowed to login or does this mean that earlier versions of Sierra Chart can still be used for charting, but cannot be used to submit orders?
[2019-02-19 15:40:03]
Sierra Chart - Max - Posts: 5780
Version 1525 and earlier will no longer be allowed to login.
To update, refer to the Fast Update instructions:
Sierra Chart Support
Date Time Of Last Edit: 2019-02-19 15:40:47
[2019-02-19 19:21:37]
If you need to use an earlier version let us know the reason and we will see how to help you with this.
