Date/Time: Sun, 26 Jan 2025 07:32:42 +0000
Why is DTN IQ Feed not listed under Supported data Services?
View Count: 684
[2019-02-19 13:56:07] |
User92573 - Posts: 541 |
Dear Support The DTN IQ Feed data service is obviously supported by Sierra but it doesn't appear in the Supported Data list. I'm just considering another data service and as my eSignal is not supported I was looking at CQG and IQ Feed. Is there a reason that DTN IQ Feed does not appear in the list? Many thanks |
[2019-02-19 18:28:16] |
Why do you want to use IQ Feed? Why not consider the Sierra Chart Exchange Data Service instead: Sierra Chart Exchange Data Feed We are also able to offer delayed London stock exchange and Euronext stock data and will be adding those soon to the Sierra Chart Exchange Data Feed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
