Date/Time: Sun, 26 Jan 2025 07:23:13 +0000
significance of UDP port?
View Count: 637
[2019-02-19 10:13:08] |
User814219 - Posts: 38 |
I recently changed the UDP port to '0' in SC Server Settings on both my main and sub-instance b/c I got a "Error binding to UDP port" message in the log. Will this impact SC funcationality in any way? What are the optimal settings for this? |
[2019-02-20 00:55:07] |
It is perfectly fine to set this to 0 to disable it. It is not something which is needed. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
