Date/Time: Sun, 26 Jan 2025 07:29:09 +0000
NO DATA!
View Count: 675
[2019-02-18 18:53:14]
TraderTen - Posts: 80
Upon login, I get a few hours of March data for today, and one bar of June data for RTY. As for R-T updates, NOTHING. Below is the log...any ideas? Thanks.
Reading Internal Order ID file. | 2019-02-18 11:26:51
Reading Trade Orders file. | 2019-02-18 11:26:51
Reading Trade Positions file. | 2019-02-18 11:26:51
Account Balance file. | 2019-02-18 11:26:51
UDPListener (836). Port 22904 | Listening on UDP port 22904. | 2019-02-18 11:26:51
Software version: 1875 32-bit | 2019-02-18 11:26:51
Usage end date: 2019-03-02 | 2019-02-18 11:26:51
Enabled for: Advanced Features. | 2019-02-18 11:26:51
Enabled for: Sierra Chart Historical Data Service. | 2019-02-18 11:26:51
Enabled for: Sierra Chart Real-Time Exchange Data Feed. | 2019-02-18 11:26:51
Enabled for: INDEXES_DATA_BARCHART | 2019-02-18 11:26:51
Enabled for: CME with Market Depth for nonprofessional Trading accounts | 2019-02-18 11:26:51
Received 1 data feed usernames. | 2019-02-18 11:26:51
Allow Support for Sierra Chart Data Feeds is enabled. | 2019-02-18 11:26:51
Current selected Data/Trading service: CQG FIX Trading | 2019-02-18 11:26:51
Chart Update Interval: 500 | 2019-02-18 11:26:51
Intraday Data Storage Time Unit: 1 | 2019-02-18 11:26:51
Time Zone: -07:00:00 (MST-07) | 2019-02-18 11:26:51
2019-02-18 11:26:51 Local computer time | 2019-02-18 11:26:51
2019-02-18 18:26:51 Local computer time in UTC | 2019-02-18 11:26:51
2019-02-18 11:26:51 Local computer time in SC Time Zone | 2019-02-18 11:26:51
2019-02-18 18:26:51 Server time in UTC | 2019-02-18 11:26:51
Local computer UTC time and Server UTC time difference: 2 seconds. | 2019-02-18 11:26:51
Program path: C:\SierraChart\ | 2019-02-18 11:26:51
Data Files path: C:\SierraChart\Data\ | 2019-02-18 11:26:51
OS Version Number: 6.1 | 2019-02-18 11:26:51
Locale Setting: C | 2019-02-18 11:26:51
DLLs: KowalT3.dll, sst_imbalance.dll, UserContributedStudies.dll, UserContributedStudies_64.dll | 2019-02-18 11:26:51
Checking for new symbol settings. Requested symbol settings MD5 for service code cqg. Request ID: 1. | 2019-02-18 11:26:51
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Creating socket. Using TLS 1.2. | 2019-02-18 11:26:51
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Connecting to IP: 46.4.97.203. | 2019-02-18 11:26:51
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-02-18 11:26:51
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-02-18 11:26:52
HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-02-18 11:26:52
Received 5 login tokens. | 2019-02-18 11:26:52
Symbol settings MD5 received. Request ID: 1. | 2019-02-18 11:26:52
Symbol settings are up-to-date for cqg. | 2019-02-18 11:26:52
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Shutdown started. Waiting for graceful close. | 2019-02-18 11:26:52
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Shutdown started. Waiting for graceful close. | 2019-02-18 11:26:52
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Socket gracefully closed by remote side. | 2019-02-18 11:26:52
HTTPS connection ID:2 to www.sierrachart.com:443 for request ID:2 (2) | Closed. | 2019-02-18 11:26:52
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Socket gracefully closed by remote side. | 2019-02-18 11:26:53
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (4) | Closed. | 2019-02-18 11:26:53
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Creating socket. Using TLS 1.2. | 2019-02-18 11:26:53
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Connecting to IP: 46.4.97.203. | 2019-02-18 11:26:53
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close. | 2019-02-18 11:26:54
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side. | 2019-02-18 11:26:55
HTTPS connection ID:1 to www.sierrachart.com:443 for request ID:1 (1) | Closed. | 2019-02-18 11:26:55
CQG FIX: Connecting to fixapi.cqgtrader.com. Port: 6925. | 2019-02-18 11:26:57
CQG FIX socket (1) | Creating socket. Using TLS 1.2. | 2019-02-18 11:26:57
CQG FIX socket (1) | Connecting to IP: 208.48.16.214. | 2019-02-18 11:26:57
CQG FIX: Sending the Logon message. | 2019-02-18 11:26:57
CQG FIX Trading | Connected to trading server. | 2019-02-18 11:26:58
CQG FIX Trading | Connecting to server api.cqg.com | 2019-02-18 11:26:58
CQG WebSocket | Connecting to WebSocket server. | 2019-02-18 11:26:58
CQG FIX | FCM name: AMP | 2019-02-18 11:26:58
CQG WebSocket socket (2) | Creating socket. Using TLS 1.2. | 2019-02-18 11:26:58
CQG WebSocket socket (2) | Connecting to IP: 208.48.16.35. | 2019-02-18 11:26:58
CQG WebSocket | Opening WebSocket. | 2019-02-18 11:26:58
CQG WebSocket | Sending WebSocket handshake. | 2019-02-18 11:26:58
CQG WebSocket | Header line. HTTP/1.1 101 Switching Protocols | 2019-02-18 11:26:58
CQG WebSocket | Header line. Connection: upgrade | 2019-02-18 11:26:58
CQG WebSocket | Header line. Sec-WebSocket-Accept: dczpqGcC/vL/0UQq+xnR7xTJoZs= | 2019-02-18 11:26:58
CQG WebSocket | Header line. Server: WebSocket++/0.7.0 | 2019-02-18 11:26:58
CQG WebSocket | Header line. Upgrade: websocket | 2019-02-18 11:26:58
CQG WebSocket | Header line. | 2019-02-18 11:26:58
CQG WebSocket | Web socket state is now open. | 2019-02-18 11:26:58
CQG FIX Trading | WebSocket connected. | 2019-02-18 11:26:58
CQG FIX Trading | Sending market data logon message. | 2019-02-18 11:26:58
CQG FIX Trading | Base Time: 2019-01-27T06:23:04. 2019-01-27 06:23:04 | 2019-02-18 11:26:59
CQG FIX Trading | Logon successful. Session Token = EPHHBp5RlbAREU4moXTQZYlzbDdSmwx6UbVmt25SYO8zergTnOmIXVE37uBz1vUoKByJLVMX8SQ | 2019-02-18 11:26:59
CQG FIX Trading | Connected to data and trading server. | 2019-02-18 11:26:59
Loading DLL C:\SierraChart\Data\KowalT3.dll | 2019-02-18 11:27:46
Loading DLL C:\SierraChart\Data\UserContributedStudies.dll | 2019-02-18 11:27:46
F.US.RTYH19 1.2 Range #1 | Reloading chart. | 2019-02-18 11:27:46
F.US.RTYH19 1.0 Range #2 | Reloading chart. | 2019-02-18 11:27:46
F.US.RTYH19 1.6 Range #3 | Reloading chart. | 2019-02-18 11:27:46
F.US.RTYH19 0.8 Range #4 | Reloading chart. | 2019-02-18 11:27:46
F.US.RTYH19 0.6 Range #5 | Reloading chart. | 2019-02-18 11:27:46
F.US.RTYH19 2.0 Range #6 | Reloading chart. | 2019-02-18 11:27:47
Mapping F.US.RTYH19 to RTYH19. Service code: cme | 2019-02-18 11:27:47
SC Data - All Services | Starting real-time market data updates for: F.US.RTYH19 (RTYH19). ID: 1 Service code: cme | 2019-02-18 11:27:47
SC Data - All Services | Using username 0 | 2019-02-18 11:27:47
SC Data - All Services | Connecting to the server ds1.sierracharts.com. Port 10048 | 2019-02-18 11:27:47
CQG FIX Trading | Sending symbol resolution request for F.US.RTYH19. ID: 269194 | 2019-02-18 11:27:47
SC Data - All Services | Requesting security definition data for: F.US.RTYH19 (RTYH19). ID: 1 | 2019-02-18 11:27:47
Intraday data recording state for symbol F.US.RTYH19 is set to download 'Pending'. | 2019-02-18 11:27:47
Delaying start of download for F.US.RTYH19 | 2019-02-18 11:27:47
CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYH19. Search Symbol: F.US.RTYH19. Request ID: 269194. Contract ID: 1. | 2019-02-18 11:27:47
DTC Client socket (3) | Creating socket. | 2019-02-18 11:27:48
DTC Client socket (3) | Connecting to IP: 8.18.161.135. | 2019-02-18 11:27:48
SC Data - All Services | Connected to server. | 2019-02-18 11:27:48
SC Data - All Services | Starting socket receive thread. | 2019-02-18 11:27:48
SC Data - All Services | Sending encoding request to server: Binary VLS | 2019-02-18 11:27:48
SC Data - All Services | Setting DTC encoding to Binary VLS | 2019-02-18 11:27:48
SC Data - All Services | Sending logon request message. | 2019-02-18 11:27:48
SC Data - All Services | Received logon response. | 2019-02-18 11:27:49
SC Data - All Services | Server Name: SC Realtime Server. | 2019-02-18 11:27:49
SC Data - All Services | Server protocol version: 8. Client protocol version: 8 | 2019-02-18 11:27:49
SC Data - All Services | Successfully connected. | 2019-02-18 11:27:49
SC Data - All Services | Trading is not supported. | 2019-02-18 11:27:49
SC Data - All Services | Restarting real-time data updates for symbol: F.US.RTYH19 -> RTYH19 | 2019-02-18 11:27:49
SC Data - All Services | Received security definition for symbol F.US.RTYH19 | 2019-02-18 11:27:49
Requesting market depth updates for: F.US.RTYH19 if supported. | 2019-02-18 11:27:50
SC Data - All Services | Clearing market depth for F.US.RTYH19. | 2019-02-18 11:27:50
HD Request # 2 | Downloading Intraday chart data for F.US.RTYH19 to the file F.US.RTYH19.scid. Service: cme | 2019-02-18 11:27:53
HD Request # 2 | Download start date-time: 2019-02-18 10:59:55.000 | 2019-02-18 11:27:53
HD Request # 2 | Using server: ds7.sierracharts.com port 10150 | 2019-02-18 11:27:53
Socket (4) | Creating socket. | 2019-02-18 11:27:53
Socket (4) | Connecting to IP: 8.18.161.133. | 2019-02-18 11:27:53
HD Request # 2 | Setting DTC encoding to Binary VLS | 2019-02-18 11:27:54
HD Request # 2 | Sending historical data logon request message. | 2019-02-18 11:27:54
HD Request # 2 | Requesting Intraday data. Start date-time: 2019-02-18 10:59:55. Record interval: 1. Symbol: RTYH19 | 2019-02-18 11:27:54
HD Request # 2 | Decompressing data. | 2019-02-18 11:27:54
HD Request # 2 | Receiving Intraday data for F.US.RTYH19 starting at 2019-02-18 10:59:55 | 2019-02-18 11:27:54
HD Request # 2 | Timestamp of first Intraday data file record written: 2019-02-18 10:59:55 | 2019-02-18 11:27:54
Socket (4) | Shutdown started. Waiting for graceful close. | 2019-02-18 11:27:54
Historical data download thread signaled to stop. | 2019-02-18 11:27:54
HD Request # 2 | Received 1 record from 2019-02-18 10:59:55 to 2019-02-18 10:59:55 (0.0 seconds) and wrote 1 record for F.US.RTYH19 | 2019-02-18 11:27:54
HD Request # 2 | Completion time: 0s | 2019-02-18 11:27:54
HD Request # 2 | Intraday data download complete for F.US.RTYH19. Unique request ID: 1 | 2019-02-18 11:27:54
Removed historical data download ID 1 | 2019-02-18 11:27:54
Real-time Intraday chart data file updates started for F.US.RTYH19 | 2019-02-18 11:27:54
Opened cached Intraday file: C:\SierraChart\Data\F.US.RTYH19.scid | 2019-02-18 11:27:54
Intraday chart data file opened for F.US.RTYH19 | 2019-02-18 11:27:54
Socket (4) | Socket gracefully closed by remote side. | 2019-02-18 11:27:54
Socket (4) | Closed. | 2019-02-18 11:27:54
F.US.RTYH19 0.6 Range #7 | Reloading chart. | 2019-02-18 11:29:25
F.US.RTYM19 [M] 0.6 Range #7 | Reloading chart. | 2019-02-18 11:29:45
Mapping F.US.RTYM19 to RTYM19. Service code: cme | 2019-02-18 11:29:45
SC Data - All Services | Starting real-time market data updates for: F.US.RTYM19 (RTYM19). ID: 2 Service code: cme | 2019-02-18 11:29:45
CQG FIX Trading | Sending symbol resolution request for F.US.RTYM19. ID: 269195 | 2019-02-18 11:29:45
SC Data - All Services | Requesting security definition data for: F.US.RTYM19 (RTYM19). ID: 2 | 2019-02-18 11:29:45
Intraday data recording state for symbol F.US.RTYM19 is set to download 'Pending'. | 2019-02-18 11:29:45
Delaying start of download for F.US.RTYM19 | 2019-02-18 11:29:45
CQG FIX Trading | Received symbol resolution report for symbol F.US.RTYM19. Search Symbol: F.US.RTYM19. Request ID: 269195. Contract ID: 2. | 2019-02-18 11:29:45
SC Data - All Services | Received security definition for symbol F.US.RTYM19 | 2019-02-18 11:29:46
Requesting market depth updates for: F.US.RTYM19 if supported. | 2019-02-18 11:29:49
SC Data - All Services | Clearing market depth for F.US.RTYM19. | 2019-02-18 11:29:49
HD Request # 3 | Downloading Intraday chart data for F.US.RTYM19 to the file F.US.RTYM19.scid. Service: cme | 2019-02-18 11:29:50
HD Request # 3 | Download start date-time: 2019-02-18 09:28:05.000 | 2019-02-18 11:29:50
HD Request # 3 | Using server: ds1.sierracharts.com port 10149 | 2019-02-18 11:29:50
Socket (5) | Creating socket. | 2019-02-18 11:29:50
Socket (5) | Connecting to IP: 8.18.161.135. | 2019-02-18 11:29:50
HD Request # 3 | Setting DTC encoding to Binary VLS | 2019-02-18 11:29:50
HD Request # 3 | Sending historical data logon request message. | 2019-02-18 11:29:50
HD Request # 3 | Requesting Intraday data. Start date-time: 2019-02-18 09:28:05. Record interval: 1. Symbol: RTYM19 | 2019-02-18 11:29:50
HD Request # 3 | Decompressing data. | 2019-02-18 11:29:50
HD Request # 3 | Receiving Intraday data for F.US.RTYM19 starting at 2019-02-18 09:28:05 | 2019-02-18 11:29:50
HD Request # 3 | Timestamp of first Intraday data file record written: 2019-02-18 09:28:05 | 2019-02-18 11:29:50
Socket (5) | Shutdown started. Waiting for graceful close. | 2019-02-18 11:29:50
Historical data download thread signaled to stop. | 2019-02-18 11:29:50
HD Request # 3 | Received 1 record from 2019-02-18 09:28:05 to 2019-02-18 09:28:05 (0.0 seconds) and wrote 1 record for F.US.RTYM19 | 2019-02-18 11:29:50
HD Request # 3 | Completion time: 0s | 2019-02-18 11:29:50
HD Request # 3 | Intraday data download complete for F.US.RTYM19. Unique request ID: 2 | 2019-02-18 11:29:50
Removed historical data download ID 2 | 2019-02-18 11:29:50
Real-time Intraday chart data file updates started for F.US.RTYM19 | 2019-02-18 11:29:50
Opened cached Intraday file: C:\SierraChart\Data\F.US.RTYM19.scid | 2019-02-18 11:29:50
Intraday chart data file opened for F.US.RTYM19 | 2019-02-18 11:29:50
Socket (5) | Socket gracefully closed by remote side. | 2019-02-18 11:29:50
Socket (5) | Closed. | 2019-02-18 11:29:50
F.US.RTYH19 [M] 0.3 Range #5 | Reloading chart. | 2019-02-18 11:32:53
F.US.RTYM19 [M] 0.3 Range #7 | Reloading chart. | 2019-02-18 11:33:22
[2019-02-18 20:04:56]
Are you aware of the CME's trading schedule? The CME closed today at 1 PM US Eastern time.
