Date/Time: Sun, 26 Jan 2025 07:41:15 +0000
unable to click on the chart window
View Count: 628
[2019-02-18 15:10:16] |
User786248 - Posts: 25 |
Hi Today I was trying to create 2 chart windows to be the same and I had the studies window for both chart windows open. When I close one study window, the other study window in the other chart minimized itself and I'm unable to find it. I am not able to reset window function as it is not allowing me to click. Is there a trick to make the hidden study window visible again so I can properly close it so my chart window starts to work again? thanks |
[2019-02-18 15:17:12] |
We do not see how this is possible to have two Chart Studies windows open at the same time. With the condition that you describe, press the Escape key to get out of that condition. Make sure you do that though on the Sierra Chart window that you cannot interact with. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2019-02-18 15:17:53
