Date/Time: Sun, 24 Nov 2024 15:39:14 +0000
User Email Question - Differences In Data
View Count: 1262
[2013-11-14 16:29:29]
Sierra Chart - Max - Posts: 5730
I've noticed something strange in the charting data, more precisely the data in real time and the data in your history servers in ** seem to be quite different.
In the 2 attached files, concerning the 6EZ3 contract in 1000 ticks version, the difference is quite clear: the one named “6eZ3 real time.jpg” is the chart obtained while following the market during the day, and the second named “6ez3 from history.jpg” is the chart obtained doing “Edit/Delete All data and download” from the Sierra menu.
It seems evident that the “real time” one has far less ticks than the “history” one.
So I'd ask you 2 questions:
1/ why the 2 charts are different ?
2/ how can I have the “history” one in (real) real time ?
Refer to help topic 43.4:
http://www.sierrachart.com/index.php?l=doc/helpdetails43.html#h43.4
Sierra Chart Support
Date Time Of Last Edit: 2013-11-14 19:15:58
[2013-11-14 19:18:03]
The solution to this is to right-click on the TransAct icon on your Windows Taskbar.
Disable the Use Mode 1 and press Save Settings. After that go into AT Charts and select File >> Disconnect and then File >> Connect to Data Feed.
