Date/Time: Sun, 26 Jan 2025 07:54:07 +0000
grid of charts
View Count: 1365
[2019-02-18 09:50:21] |
arruga - Posts: 253 |
Hi I have 8 charts which I'd like to display as a 4x2 grid on my screen. All the tiling options offer don't do it. Also, using any of the automatic tiling options reorders my charts in an undesired way. Is there any way to, after manually approaching the rid to the desired state, activate some pinging of sorts to perfect the gridding? |
[2019-02-18 10:44:37] |
Graham - Posts: 44 |
Hi, Global Settings General Settings General 4 Tab At the bottom: "Use Windows Custom Grid Layout" |
[2019-02-18 21:59:13] |
What you want to do can be fully accomplished and is documented here: Window, CB and CW Menus: Tile as Grid - Horizontally (Window) Be sure to read that documentation because it explains everything you need to do. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
